はじめに
This guide will aid you in the process of removing the battery of the device. This is useful in replacing a broken or dis-functioning battery.
必要な工具と部品
Make sure the screen is facing away from you and the back cover is facing you.
Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
Grasp the circuit connected to the battery via wires.
Slide the wires from the circuit to detach it.
4 の人々がこのガイドを完成させました。
