メインコンテンツにスキップ
Nabi 2 Headphone Jack Replacement
必要な工具と部品
  1. Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: 手順 1、 3の画像 1 Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: 手順 1、 3の画像 2 Nabi 2 Headphone Jack Replacement, Nabi 2 Back Cover Removal: 手順 1、 3の画像 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Headphone Jack Replacement: 手順 2、 2の画像 1 Nabi 2 Headphone Jack Replacement: 手順 2、 2の画像 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Headphone Jack Replacement: 手順 3、 3の画像 1 Nabi 2 Headphone Jack Replacement: 手順 3、 3の画像 2 Nabi 2 Headphone Jack Replacement: 手順 3、 3の画像 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Headphone Jack Replacement, Screen: 手順 4、 3の画像 1 Nabi 2 Headphone Jack Replacement, Screen: 手順 4、 3の画像 2 Nabi 2 Headphone Jack Replacement, Screen: 手順 4、 3の画像 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2 Headphone Jack Replacement: 手順 5、 3の画像 1 Nabi 2 Headphone Jack Replacement: 手順 5、 3の画像 2 Nabi 2 Headphone Jack Replacement: 手順 5、 3の画像 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
  6. Nabi 2 Headphone Jack Replacement, Battery: 手順 6、 3の画像 1 Nabi 2 Headphone Jack Replacement, Battery: 手順 6、 3の画像 2 Nabi 2 Headphone Jack Replacement, Battery: 手順 6、 3の画像 3
    • Use the spudger to pop the battery out of place and set it aside.
  7. Nabi 2 Headphone Jack Replacement: 手順 7、 3の画像 1 Nabi 2 Headphone Jack Replacement: 手順 7、 3の画像 2 Nabi 2 Headphone Jack Replacement: 手順 7、 3の画像 3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
  8. Nabi 2 Headphone Jack Replacement, Internal Speakers: 手順 8、 1の画像 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  9. Nabi 2 Headphone Jack Replacement: 手順 9、 3の画像 1 Nabi 2 Headphone Jack Replacement: 手順 9、 3の画像 2 Nabi 2 Headphone Jack Replacement: 手順 9、 3の画像 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  10. Nabi 2 Headphone Jack Replacement: 手順 10、 1の画像 1
    • Once the screws have been removed, remove the speakers from the device.
  11. Nabi 2 Headphone Jack Replacement, Motherboard: 手順 11、 2の画像 1 Nabi 2 Headphone Jack Replacement, Motherboard: 手順 11、 2の画像 2
    • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
  12. Nabi 2 Headphone Jack Replacement: 手順 12、 3の画像 1 Nabi 2 Headphone Jack Replacement: 手順 12、 3の画像 2 Nabi 2 Headphone Jack Replacement: 手順 12、 3の画像 3
    • Remove the tape that is attaching the motherboard to the plastic casing
  13. Nabi 2 Headphone Jack Replacement: 手順 13、 3の画像 1 Nabi 2 Headphone Jack Replacement: 手順 13、 3の画像 2 Nabi 2 Headphone Jack Replacement: 手順 13、 3の画像 3
    • Remove the motherboard by lifting from the area indicated
  14. Nabi 2 Headphone Jack Replacement, Headphone Jack: 手順 14、 3の画像 1 Nabi 2 Headphone Jack Replacement, Headphone Jack: 手順 14、 3の画像 2 Nabi 2 Headphone Jack Replacement, Headphone Jack: 手順 14、 3の画像 3
    • Desolder the six pins attaching the headphone jack to the motherboard
    • Remove headphone jack from motherboard
終わりに
作成者
1人の作成者と共同作成されました。
Amy
メンバー登録日: 02/10/16
285 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 4-3, Lacy Spring 2016 USF Tampa, Team 4-3, Lacy Spring 2016人のメンバー
USFT-LACY-S16S4G3
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 1,276
