はじめに
This guide will demonstrate how to remove and replace your Nabi 2's charging port. The charging port allows the charging cable to attach to the device, and over time the part may stop functioning correctly. There are many reasons to perform this repair, but the most common causes are the port becoming loose, and the device not charging. This repair involves the use of a soldering iron; be very careful not to touch the hot end of the iron while it is plugged in. It is recommended to document the order of the charging port wires before you detach them so that you can attach the new battery's wires in the correct order.
必要な工具と部品
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using the soldering iron, detach the speaker's wires from the circuit board.
Using a soldering iron, desolder the charging port from the motherboard
Remove the charging port completely
If the glue does not completely detach from the board, try to heat it until the charging port can be removed
7 件のコメント
Naw they are still a handy fairly tough tablet for the kids shame about badly designed dc port I managed to find ports for it on ebay.
send me a new nabi in the mail today
