はじめに
Before beginning this guide we recommend following our Nabi 2 back cover removal guide.
This guide will walk you through the steps of replacing a cracked or otherwise non functioning screen on a Nabi 2. As the screen is glued to the front assembly, we recommend replacing the entire display assembly.
Be sure to use caution when releasing the clips that secure the display ribbon cables. Use a plastic spudger and push directly out, do not pry up on the clips, they will break.
必要な工具と部品
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
6 の人々がこのガイドを完成させました。
3 件のコメント
Is the LCD glued to the front glass/digitizer?
Brent Huff - 返信
It Worked Thank U So Much!!!
