メインコンテンツにスキップ
NZXT H510i ATX Mid Tower Power Supply Replacement
必要な工具と部品
  1. NZXT H510i ATX Mid Tower Power Supply Replacement, Power Supply: 手順 1、 2の画像 1 NZXT H510i ATX Mid Tower Power Supply Replacement, Power Supply: 手順 1、 2の画像 2
    • Shut down the computer.
  2. NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 2、 2の画像 1 NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 2、 2の画像 2
    • Turn off the computer using the switch on the power supply. Unplug the power cable from the power supply.
    • This step is very important. Otherwise the computer will still be powered and it could damage its components or get you an electrical shock.
  3. NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 3、 1の画像 1
    • Drain the capacitors by pressing the power switch.
    • Wait several minutes after doing this to ensure that the capacitors are drained of all residual power.
    • Put on the anti-static wrist strap.
    • Caution: This step is crucial in order to avoid personal injury and damage to the computer from electrical discharge.
  4. NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 4、 1の画像 1
    • Remove the side panel by unscrewing the captive thumb screws keeping it in place. There will be one towards the top of the panel and another towards the bottom.
  5. NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 5、 1の画像 1
    • Identify the old power supply that will be replaced. As shown, it should be towards the bottom of the case, and towards the back of the computer.
    • Take a picture of how the cables are arranged so that this can be replicated later.
  6. NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 6、 3の画像 1 NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 6、 3の画像 2 NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 6、 3の画像 3
    • Unplug the various power cables. These include the processor's power cable, the graphics card power cable, the SATA cables for the fan control, and the motherboard's power cable
  7. NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 7、 3の画像 1 NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 7、 3の画像 2 NZXT H510i ATX Mid Tower Power Supply Replacement: 手順 7、 3の画像 3
    • Using a Phillips #0 screwdriver, remove the four 6-32 x 6mm screws attached to the power supply.
    • Remove the old power supply from the case.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Graeme McCord
メンバー登録日: 10/08/20
307 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S3-G16, Willis Fall 2020 University of Memphis, Team S3-G16, Willis Fall 2020人のメンバー
UM-WILLIS-F20S3G16
1 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 72
今までの合計 3,676
