はじめに
On the NPET K10V3, if some keys are not working or lights are not responding to user commands, follow these steps to solve this issue. This could be an issue with your keyboard membrane as it may have been damaged or has a bad connection. The membrane has multiple routed connections to allow for each function of the keyboard's lighting or digital input.
Hazards:
- Electrostatic shock
- Sharp objects
- Exposed circuits
Special Requirements:
- Remove keyboard from power source
- Clean & organized workstation
- Careful removal of delicate parts
必要な工具と部品
Flip the keyboard over so the bottom is facing upwards.
Remove fifteen 4.5 mm screws using a Phillips #2 screwdriver.
Remove three 9 mm screws using a Phillips #2 screwdriver.
ある他の人がこのガイドを完成しました。
