メインコンテンツにスキップ
NIkon Coolpix A900 I/O Cover Replacement
必要な工具と部品
  1. NIkon Coolpix A900 I/O Cover Replacement, Battery: 手順 1、 1の画像 1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. NIkon Coolpix A900 I/O Cover Replacement: 手順 2、 2の画像 1 NIkon Coolpix A900 I/O Cover Replacement: 手順 2、 2の画像 2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. NIkon Coolpix A900 I/O Cover Replacement: 手順 3、 2の画像 1 NIkon Coolpix A900 I/O Cover Replacement: 手順 3、 2の画像 2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. NIkon Coolpix A900 I/O Cover Replacement, Rear Case: 手順 4、 3の画像 1 NIkon Coolpix A900 I/O Cover Replacement, Rear Case: 手順 4、 3の画像 2 NIkon Coolpix A900 I/O Cover Replacement, Rear Case: 手順 4、 3の画像 3
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. NIkon Coolpix A900 I/O Cover Replacement: 手順 5、 3の画像 1 NIkon Coolpix A900 I/O Cover Replacement: 手順 5、 3の画像 2 NIkon Coolpix A900 I/O Cover Replacement: 手順 5、 3の画像 3
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. NIkon Coolpix A900 I/O Cover Replacement: 手順 6、 3の画像 1 NIkon Coolpix A900 I/O Cover Replacement: 手順 6、 3の画像 2 NIkon Coolpix A900 I/O Cover Replacement: 手順 6、 3の画像 3
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. NIkon Coolpix A900 I/O Cover Replacement: 手順 7、 2の画像 1 NIkon Coolpix A900 I/O Cover Replacement: 手順 7、 2の画像 2
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. NIkon Coolpix A900 I/O Cover Replacement: 手順 8、 2の画像 1 NIkon Coolpix A900 I/O Cover Replacement: 手順 8、 2の画像 2
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. NIkon Coolpix A900 I/O Cover Replacement: 手順 9、 3の画像 1 NIkon Coolpix A900 I/O Cover Replacement: 手順 9、 3の画像 2 NIkon Coolpix A900 I/O Cover Replacement: 手順 9、 3の画像 3
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: 手順 10、 3の画像 1 NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: 手順 10、 3の画像 2 NIkon Coolpix A900 I/O Cover Replacement, I/O Cover: 手順 10、 3の画像 3
    • Locate the I/O cover on the rear case.
    • On the inside of the case, unhook the I/O cover by lifting up.
    • You may not need the spudger to remove the cover.
  11. NIkon Coolpix A900 I/O Cover Replacement: 手順 11、 1の画像 1
    • Remove the I/O cover by gently pulling away from the rear case.
終わりに
作成者
1人の作成者と共同作成されました。
Andres Aronstam
メンバー登録日: 09/17/19
735 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 431
