メインコンテンツにスキップ
NETGEAR WPN824 v3 Top LED Controller Replacement
必要な工具と部品
  1. NETGEAR WPN824 v3  Top LED Controller  Replacement, Remove Screw Covers: 手順 1、 1の画像 1
    • Turn the device upside down. Remove the 4 rubber screw covers at each corner.
    • Pinch the screw covers and pull them up slowly. You may have to twist and turn them around to get them detached.
  2. NETGEAR WPN824 v3  Top LED Controller  Replacement, Remove Screws: 手順 2、 1の画像 1
    • Remove the six 3mm T15 Torx screws. Four screws on the corner of the router and two in the middle
    • Use your T15 Torx Screwdriver on each screw and set them aside. These are the only screws you need to remove throughout the repair.
  3. NETGEAR WPN824 v3  Top LED Controller  Replacement, Remove Back Cover: 手順 3、 1の画像 1
    • Once the screws have been removed you can remove the cover to reveal the motherboard.
    • You can use the ESD-safe pry tool on one of the small side openings to pry it open.
  4. NETGEAR WPN824 v3  Top LED Controller  Replacement, Detach Cable From LED Controller: 手順 4、 2の画像 1 NETGEAR WPN824 v3  Top LED Controller  Replacement, Detach Cable From LED Controller: 手順 4、 2の画像 2
    • Now that you have the case off you can slowly lift the motherboard from the top case piece.
    • Detach the cable connecting the LED controller to the motherboard. Place the motherboard aside. You will now have access to the LED Controller.
  5. NETGEAR WPN824 v3  Top LED Controller  Replacement, Detach LED Controller: 手順 5、 1の画像 1
    • The LED Controller will be pinned down by some plastic clips. Use the ESD-safe pry tool to detach the LED controller.
    • WARNING: There are 4 clips and they are transparent. Detach all of them before removing the controller. Handle the clips and LED controller with care.
  6. NETGEAR WPN824 v3  Top LED Controller  Replacement, Final Step: 手順 6、 1の画像 1
    • Now that you have detached the controller you can slowly lift it out of the plastic holds.
    • Congratulations! You have successfully removed the LED controller!
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Raul J Montes
メンバー登録日: 05/21/19
178 ポイント
1ガイドが承認済み
コメント 1 件
tl;dr
1. Take out led controller.
2. Examine what I have done.
funkybluemonkey3 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 190
