メインコンテンツにスキップ
NERF Doomlands 2169 Lawbringer Blaster Spring Replacement
必要な工具と部品
  1. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: 手順 1、 2の画像 1 NERF Doomlands 2169 Lawbringer Blaster Spring Replacement, Spring: 手順 1、 2の画像 2
    • Remove sixteen screws from the outer case.
    • Remove the outer case from the rest of the device.
  2. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 2、 1の画像 1
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Potential for device damage: Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out!
  3. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 3、 1の画像 1
    • Remove the exterior spring from the sliding mechanism and rotate the gun to the opposite side.
  4. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 4、 2の画像 1 NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 4、 2の画像 2
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
  5. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 5、 1の画像 1
    • Remove the spring and trigger mechanism from the gun and set aside.
  6. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 6、 1の画像 1
    • Carefully slide out the big spring and fit in your replacement (the thin-coil end is coiled around the orange plastic).
    • Potential for device damage: This is where the spring load mechanism is located. Be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
  7. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 7、 1の画像 1
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
    • Make sure the orange slide is above the spring. A second set of hands would be useful during this step.
  8. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 8、 1の画像 1
    • Reconnect the spring to the orange slider and connect the orange slider to the grey hook.
  9. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 9、 1の画像 1
    • Slide the orange supporting piece into the crevice below the air chamber.
  10. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 10、 1の画像 1
    • Slide the rotating cartridge back into place.
  11. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 11、 1の画像 1
    • Carefully reassemble the NERF Lawbringer in the same order you took it apart. Carefully reattach the three screws that seal the air chamber.
  12. NERF Doomlands 2169 Lawbringer Blaster Spring Replacement: 手順 12、 1の画像 1
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
ゴール
作成者
8人の作成者と共同で作成されました。
Georgia Slack
メンバー登録日: 10/13/16
113 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 1-5, Diaz Fall 2016 University of Maine, Team 1-5, Diaz Fall 2016人のメンバー
UMAINE-DIAZ-F16S1G5
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,021
