メインコンテンツにスキップ
NERF Doomlands 2169 Lawbringer Blaster Catch Spring Replacement
必要な工具と部品
  1. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: 手順 1、 2の画像 1 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: 手順 1、 2の画像 2
    • Locate and remove all 14 screws of the outer case and gently remove it avoiding any damage.
  2. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 2、 1の画像 1
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out.
  3. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 3、 1の画像 1
    • Remove the exterior spring from the sliding mechanism and re-position the gun on its opposite side.
  4. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 4、 1の画像 1
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
  5. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 5、 1の画像 1
    • Remove the spring and trigger mechanism from the gun, and set aside.
  6. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 6、 1の画像 1
    • This is where the spring load mechanism is located, be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
    • Carefully slide out the big spring and fit in your replacement (thin-coil end coiled around the orange plastic)
  7. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 7、 1の画像 1
    • A second set of hands would be useful during this step. Make sure the orange slide is above the spring.
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
  8. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 8、 1の画像 1
    • Reconnect the spring to the orange slider, and connect the orange slider to the grey hook.
  9. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 9、 2の画像 1 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 9、 2の画像 2
    • Slide the orange supporting piece into the crevice below the air chamber.
    • Slide the rotating cartridge back into place
  10. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 10、 2の画像 1 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: 手順 10、 2の画像 2
    • Look to the beginning of this guide for help to reassemble this gun.
    • Carefully reassemble the Nerf Law bringer in the same order you took it apart. Carefully reattach the 3 screws that seal the air chamber.
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Daniel Perriello
メンバー登録日: 11/04/15
134 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 1-4, Diaz Fall 2015 University of Maine, Team 1-4, Diaz Fall 2015人のメンバー
UMAINE-DIAZ-F15S1G4
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 7
今までの合計 1,945
