はじめに
Replacing the screen isn't so much difficult as a lengthy process. There will be a lot of screws removed and a lot of parts coming off, so keep track of everything.
必要な工具と部品
Place the monitor screen face up.
Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
Continue your way around the screen.
Pull the the metal casing off of the monitor to reveal the motherboards.
I have a similar monitor and the power switch is broken. I need to get inside and try to fix it
Thank you
Unplug the pink and light blue attachments from the side of the brown board by pulling up on the tabs and gently pulling the cord out.
コメント 1 件
Thank you very much for this tutorial. The steps are very specific and detailed. I bought a new NEC LCD1770NX LCD Display Screen online and installed it according to the steps in the article. Finally, the machine worked normally again. Thank you very much.
