1. Place the monitor face down on a clean, flat surface. Place the monitor face down on a clean, flat surface.
    • Place the monitor face down on a clean, flat surface.
  2. Firmly remove the back panel of the stand by pulling it up and away from the monitor. Firmly remove the back panel of the stand by pulling it up and away from the monitor.
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand. Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Firmly grasp the stand enclosure with your hand and slide it to base of stand. Firmly grasp the stand enclosure with your hand and slide it to base of stand.
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Lift the the stand straight up to remove it. Lift the the stand straight up to remove it.
    • Lift the the stand straight up to remove it.
  7. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  8. Place the monitor screen face up. Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off. Continue your way around the screen.
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  9. Unscrew the two 7mm screws from the bottom of the button assembly. Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur. Pull the button assembly out a few inches and unplug the colored cables.
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  10. Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor. Remove the button assembly from the monitor.
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  11. With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  12. Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure. Carefully pull the enclosure off the monitor. Carefully pull the enclosure off the monitor.
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  13. Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor. Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  14. Pull  the the metal casing off of the monitor to reveal the motherboards. Pull  the the metal casing off of the monitor to reveal the motherboards.
    • Pull the the metal casing off of the monitor to reveal the motherboards.
  15. Carefully insert the prying tool underneath the power supply fuse. Using the prying tool, lift the power supply fuse out of its emplacement until it is resting on its clamps.
    • Carefully insert the prying tool underneath the power supply fuse.
    • Using the prying tool, lift the power supply fuse out of its emplacement until it is resting on its clamps.
  16. Carefully remove the power supply fuse by hand.
    • Carefully remove the power supply fuse by hand.
  17. Place the replacement power supply fuse on the fuse clips. With a finger, press down on the ends of the replacement fuse until it is properly seated in the fuse clips. With a finger, press down on the ends of the replacement fuse until it is properly seated in the fuse clips.
    • Place the replacement power supply fuse on the fuse clips.
    • With a finger, press down on the ends of the replacement fuse until it is properly seated in the fuse clips.
まとめ
Drew Troxell
メンバー登録日: 2013年10月18日
113 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-36, Amido Fall 2013 Cal Poly, Team 11-36, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G36
5 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 465
