はじめに
If the speakers not working, or they are only making a static noise, then replacing them will fix the sound of the NABI XD.
必要な工具と部品
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Remove the two 4mm Phillips screws with the PH#0 screwdriver.
Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
Right (R) speaker removal:
Remove one 4mm Phillips screw.
Use the metal spudger to separate the speaker from the frame.
