はじめに
With a simple modification to a single resistor already on the N64 Rumble Pak it can be made to rumble without batteries. This means more $ in your pocket and 0% chance of leaky acid on your components. I don’t take credit for this discovery but I am here to pass the knowledge on to you good people.
パーツ
パーツは指定されていません。
Remove the 2 3.8mm gamebit screws
Disassemble the rumble pak and set the plastic housing aside.
Desolder the resistor just above the battery location on the pcb
Resolder the same resistor to the following through hole locations and solder into place. Conveniently, the resistor leads are long enough to reach these points and not require any extra wires.
Clean up any flux you might have used and since the board is out you might as well give it a good clean with a electronic cleaner or high content isopropyl alcohol.
Reassemble the rumble pak and screw in the gamebit screws.
Enjoy the battery free rumble of your N64 Rumble Pak. Thanks for reading and game on!
