はじめに
If your speaker in not functioning correctly, follow this guide and replace the speaker.
必要な工具と部品
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the slim plastic opening tool to remove the speaker from its position on the case.
もう少しです!
終わりに
