メインコンテンツにスキップ
Munchkinz Motherboard Replacement
必要な工具と部品
  1. Munchkinz Motherboard Replacement, Opening Device: 手順 1、 1の画像 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Motherboard Replacement, Pry Device Apart: 手順 2、 2の画像 1 Munchkinz Motherboard Replacement, Pry Device Apart: 手順 2、 2の画像 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Motherboard Replacement, Separated Device: 手順 3、 1の画像 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Motherboard Replacement, Pry Camera: 手順 4、 1の画像 1
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Motherboard Replacement, Disconnect Ribbon: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
  6. Munchkinz Motherboard Replacement, Pry Speaker: 手順 6、 2の画像 1 Munchkinz Motherboard Replacement, Pry Speaker: 手順 6、 2の画像 2
    • Use the slim plastic opening tool to remove the speaker from its position on the case.
  7. Munchkinz Motherboard Replacement, Locate Wires: 手順 7、 1の画像 1
    • Locate the red and black wires that connect the speaker to the motherboard.
  8. Munchkinz Motherboard Replacement, Solder Wires: 手順 8、 1の画像 1
    • Un-solder the red and black speaker wires that are connected to the motherboard
  9. Munchkinz Motherboard Replacement, Volume Button: 手順 9、 1の画像 1
    • Remove the plastic volume button.
  10. Munchkinz Motherboard Replacement, Unscrew Module: 手順 10、 1の画像 1
    • Remove the two screws that hold the volume button assembly in place.
  11. Munchkinz Motherboard Replacement, Solder Module Wires: 手順 11、 1の画像 1
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
  12. Munchkinz Motherboard Replacement, Removing battery: 手順 12、 3の画像 1 Munchkinz Motherboard Replacement, Removing battery: 手順 12、 3の画像 2 Munchkinz Motherboard Replacement, Removing battery: 手順 12、 3の画像 3
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  13. Munchkinz Motherboard Replacement, Remove battery completely: 手順 13、 1の画像 1
    • Use the Soldering Iron to disconnect the each cable.
  14. Munchkinz Motherboard Replacement, Remove Tape: 手順 14、 1の画像 1
    • Remove black tape covering any of the ribbons that have it.
  15. Munchkinz Motherboard Replacement, Remove Ribbons: 手順 15、 1の画像 1
    • Pull the ribbons out from the plugs.
  16. Munchkinz Motherboard Replacement, Remove Camera/Hidden Screw: 手順 16、 1の画像 1
    • After removing the camera, remove the hidden screw.
  17. Munchkinz Motherboard Replacement, Remove Screws: 手順 17、 1の画像 1
    • Remove screws located on the opposite side of the battery.
  18. Munchkinz Motherboard Replacement, Lift: 手順 18、 1の画像 1
    • Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
終わりに
作成者
4人の作成者と共同で作成されました。
Austin Oliveira
メンバー登録日: 02/05/15
204 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015人のメンバー
UWT-ROSE-W15S3G6
3 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 269
