メインコンテンツにスキップ
Munchkinz LCD Assembly
必要な工具と部品
  1. Munchkinz LCD Assembly, Opening Device: 手順 1、 1の画像 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz LCD Assembly, Pry Device Apart: 手順 2、 2の画像 1 Munchkinz LCD Assembly, Pry Device Apart: 手順 2、 2の画像 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz LCD Assembly, Separated Device: 手順 3、 1の画像 1
    • After prying the device apart, it should look like this.
  4. Munchkinz LCD Assembly, Remove Speaker: 手順 4、 1の画像 1
    • Use the plastic opening tool to remove the speaker from the casing.
  5. Munchkinz LCD Assembly, Pry Camera: 手順 5、 1の画像 1
    • Use the slim plastic opening tool to pry the camera from its position.
  6. Munchkinz LCD Assembly, Unscrew Volume Module: 手順 6、 2の画像 1 Munchkinz LCD Assembly, Unscrew Volume Module: 手順 6、 2の画像 2
    • Unscrew the two screws that hold the volume module to the casing.
  7. Munchkinz LCD Assembly, Pry Battery: 手順 7、 1の画像 1
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  8. Munchkinz LCD Assembly, Remove Ribbons: 手順 8、 1の画像 1
    • Remove the two highlighted ribbons from the motherboard.
  9. Munchkinz LCD Assembly, Remove Screws: 手順 9、 1の画像 1
    • Use the screw driver to remove the highlighted screws.
  10. Munchkinz LCD Assembly, Remove Hidden Screw: 手順 10、 1の画像 1
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
  11. Munchkinz LCD Assembly, Remove Motherboard: 手順 11、 1の画像 1
    • Remove the motherboard from the casing.
  12. Munchkinz LCD Assembly, Pry Up Screen: 手順 12、 3の画像 1 Munchkinz LCD Assembly, Pry Up Screen: 手順 12、 3の画像 2 Munchkinz LCD Assembly, Pry Up Screen: 手順 12、 3の画像 3
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
  13. Munchkinz LCD Assembly, Solder LCD Wires: 手順 13、 1の画像 1
    • Unsolder the black and red LCD wires.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
David Wood
メンバー登録日: 02/05/15
440 ポイント
4のガイドは作成済み
チーム
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015人のメンバー
UWT-ROSE-W15S3G6
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 15
今までの合計 356
