はじめに
Replacing the power cord on the TF6 requires several wiring tools and previous experience with soldering. For soldering tips and directions, consult the guide on how to solder and desolder connections.
必要な工具と部品
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
もう少しです!
終わりに
