はじめに
To complete this repair you will need pilers, a Philips head screwdriver, and a flathead screw driver. During this repair you will remove the base of the coffee machine, loosen the support bar, before finally removing the heating plate and prying out the O-ring.
必要な工具と部品
Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
この手順で使用する道具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead Screwdriver to pry out the O-ring.
3 の人々がこのガイドを完成させました。
