はじめに
To complete this repair you will need pilers, a Philips head screwdriver, and a flathead screw driver. During this repair you will remove the base of the coffee machine, loosen the support bar, before finally removing the heating plate and prying out the O-ring.
  1. Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean. Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver. Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Gently lift the base cover to expose the inside of the coffee machine.
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver. Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
  5. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  6. Gently lift the silver support bracket freeing the heating plate from the heating coil.
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  7. Use needle-nose pilers to pinch and loosen the crimps Use needle-nose pilers to pinch and loosen the crimps
    • Use needle-nose pilers to pinch and loosen the crimps
  8. Once the crimps are loosened, slide them down the tubing.
    • Once the crimps are loosened, slide them down the tubing.
  9. Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart. Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  10. Place one of your hands on the front side of the heating plate. Use this hand to gently push the heating plate towards yourself and out of the machine.
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
  11. Use a 2.5 mm Flathead Screwdriver to pry out the O-ring. Use a 2.5 mm Flathead Screwdriver to pry out the O-ring.
    • Use a 2.5 mm Flathead Screwdriver to pry out the O-ring.
まとめ
3 の人々がこのガイドを完成させました。
Madeline Landis
メンバー登録日: 2014年01月21日
122 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-31, Maness Winter 2014 Cal Poly, Team 10-31, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G31
4 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 685
