はじめに
In order to remove the base of your Mr. Coffee DW13, you will need to position the coffee machine so that the bottom is facing you. After, you will remove eight screws and gently lift the cover from the base.
必要な工具と部品
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
