メインコンテンツにスキップ
Mpow MPBH063 Motherboard Replacement
必要な工具と部品
  1. Mpow MPBH063 Motherboard Replacement, Battery: 手順 1、 3の画像 1 Mpow MPBH063 Motherboard Replacement, Battery: 手順 1、 3の画像 2 Mpow MPBH063 Motherboard Replacement, Battery: 手順 1、 3の画像 3
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Motherboard Replacement: 手順 3、 1の画像 1
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
  4. Mpow MPBH063 Motherboard Replacement: 手順 4、 1の画像 1
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
  5. Mpow MPBH063 Motherboard Replacement, Motherboard: 手順 5、 1の画像 1
    • Unplug all wires that are connected to the motherboard.
  6. Mpow MPBH063 Motherboard Replacement: 手順 6、 2の画像 1 Mpow MPBH063 Motherboard Replacement: 手順 6、 2の画像 2
    • Detach the motherboard from the speaker using the tech knife and the adhesive remover to remove the adhesive securing the motherboard.
    • Use iFixit Adhesive Remover as directed.
    • Use the precision tweezers with the blunt head to carefully grip and pull out the motherboard.
    • Proceed with caution when using the tech knife and removing the motherboard as you do not want to cause injury to yourself or the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Lianna Cook
メンバー登録日: 10/09/18
248 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team S15-G5, Blackburne Fall 2018 Sam Houston State, Team S15-G5, Blackburne Fall 2018人のメンバー
SHSU-BLACKBURNE-F18S15G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 8
今までの合計 1,768
