はじめに
If you have identified an issue with your speaker’s indicator light bulb and need to replace it, use this guide to help you replace the light bulb. In order to remove and replace the indicator light bulb of your MPOW Armor speaker, you will need a T6 and JIS #00 head screwdriver.
必要な工具と部品
Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
Use the adhesive remover to loosen the light bulb.
Gently remove bulb with the precision tweezers.
