メインコンテンツにスキップ
Motorola i886 Slide-out Keyboard Replacement
必要な工具と部品
  1. Motorola i886 Slide-out Keyboard Replacement, Back Cover: 手順 1、 2の画像 1 Motorola i886 Slide-out Keyboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Undo the headphone jack and USB port cover with your fingertip. Place your middle finger in the indent on the upper left side of the back of the phone.
  2. Motorola i886 Slide-out Keyboard Replacement, Open: 手順 2、 1の画像 1
    • Pull back until cover is removed. Place cover aside.
  3. Motorola i886 Slide-out Keyboard Replacement, Battery: 手順 3、 1の画像 1
    • Locate battery and use your index finger to grasp the upper left side of the battery and pull back to remove. Set battery aside.
  4. Motorola i886 Slide-out Keyboard Replacement, SIM Card: 手順 4、 1の画像 1
    • Locate and use your thumb to slide the SIM card to the right until it is removed and set it aside.
  5. Motorola i886 Slide-out Keyboard Replacement, Screw Removal: 手順 5、 2の画像 1 Motorola i886 Slide-out Keyboard Replacement, Screw Removal: 手順 5、 2の画像 2
    • Remove eight black .4 centimeter screws on the top, bottom, and sides of the phone with a T5 Torx screwdriver by inserting it into the screws and turning it to the left. Set screws aside.
  6. Motorola i886 Slide-out Keyboard Replacement, Separating: 手順 6、 1の画像 1
    • Loosen four fastener pieces on the side and bottom with a plastic opening tool to pry them backwards.
    • Insert the plastic opening tool between the loosened casing and the rest of the phone and pry the two pieces apart to remove the casing.
  7. Motorola i886 Slide-out Keyboard Replacement: 手順 7、 1の画像 1
    • Remove the .3 centimeter silver screw with the T5 Torx screwdriver.
    • Use your fingertips to lift up the circuit board and lay it on the side of the phone. Note that the two pieces are attached by a gold and black strip.
  8. Motorola i886 Slide-out Keyboard Replacement, Keyboard Removal: 手順 8、 1の画像 1
    • Locate and grip the black, white, and blue keyboard layer with your fingernail, lift up to remove it.
終わりに
作成者
1人の作成者と共同作成されました。
Felicita Correa
メンバー登録日: 09/03/14
418 ポイント
4のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014人のメンバー
USFSM-STEWART-F14S1G2
3 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 14
今までの合計 225
