メインコンテンツにスキップ
Motorola i710 LCD Screen Replacement
必要な工具と部品
  1. Motorola i710 LCD Screen Replacement, Battery Cover: 手順 1、 2の画像 1 Motorola i710 LCD Screen Replacement, Battery Cover: 手順 1、 2の画像 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 LCD Screen Replacement, Battery: 手順 2、 1の画像 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 LCD Screen Replacement, LCD Screen Cover: 手順 3、 3の画像 1 Motorola i710 LCD Screen Replacement, LCD Screen Cover: 手順 3、 3の画像 2 Motorola i710 LCD Screen Replacement, LCD Screen Cover: 手順 3、 3の画像 3
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  4. Motorola i710 LCD Screen Replacement: 手順 4、 2の画像 1 Motorola i710 LCD Screen Replacement: 手順 4、 2の画像 2
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  5. Motorola i710 LCD Screen Replacement: 手順 5、 3の画像 1 Motorola i710 LCD Screen Replacement: 手順 5、 3の画像 2 Motorola i710 LCD Screen Replacement: 手順 5、 3の画像 3
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
  6. Motorola i710 LCD Screen Replacement, LCD Screen: 手順 6、 3の画像 1 Motorola i710 LCD Screen Replacement, LCD Screen: 手順 6、 3の画像 2 Motorola i710 LCD Screen Replacement, LCD Screen: 手順 6、 3の画像 3
    • Use a spudger to detach the ribbon cable connecting the the LCD Screen to the rest of the phone.
    • The LCD Scren will now lift out from the phone casing.
    • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Carson Meena
メンバー登録日: 10/22/12
16 ポイント
5のガイドは作成済み
チーム
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012人のメンバー
CLEM-BENSON-F12S14G2
4 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 400
