メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola i710 Keypad Cover Replacement
必要な工具と部品
  1. Motorola i710 Keypad Cover Replacement, Battery Cover: 手順 1、 2の画像 1 Motorola i710 Keypad Cover Replacement, Battery Cover: 手順 1、 2の画像 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    FixBotに聞いてみる
    コメントを追加
  2. Motorola i710 Keypad Cover Replacement, Battery: 手順 2、 1の画像 1
    • Push the battery towards the top of the phone and lift up.
    FixBotに聞いてみる
    コメントを追加
  3. Motorola i710 Keypad Cover Replacement, Back Casing: 手順 3、 3の画像 1 Motorola i710 Keypad Cover Replacement, Back Casing: 手順 3、 3の画像 2 Motorola i710 Keypad Cover Replacement, Back Casing: 手順 3、 3の画像 3
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    FixBotに聞いてみる
    コメントを追加
  4. Motorola i710 Keypad Cover Replacement, Motherboard: 手順 4、 3の画像 1 Motorola i710 Keypad Cover Replacement, Motherboard: 手順 4、 3の画像 2 Motorola i710 Keypad Cover Replacement, Motherboard: 手順 4、 3の画像 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
    FixBotに聞いてみる
    コメントを追加
  5. Motorola i710 Keypad Cover Replacement, Keypad Sensor: 手順 5、 2の画像 1 Motorola i710 Keypad Cover Replacement, Keypad Sensor: 手順 5、 2の画像 2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
    FixBotに聞いてみる
    コメントを追加
  6. Motorola i710 Keypad Cover Replacement, Keypad Cover: 手順 6、 2の画像 1 Motorola i710 Keypad Cover Replacement, Keypad Cover: 手順 6、 2の画像 2
    • Once the keypad has been removed, the keypad cover can be easily peeled back from the front phone cover molding.
    • Care must be taken when inserting a new keypad cover. The keypad cover will have to be lined up to the corresponding holes of the phone casing.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
6人の作成者と共同で作成されました。
Katelyn
メンバー登録日: 10/22/12
1 ポイント
2のガイドは作成済み
チーム
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012人のメンバー
CLEM-BENSON-F12S14G2
4 メンバー
41のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 36
今までの合計 744
