はじめに
Once the back casing has been removed, the charger cover will be accessible for replacement.
必要な工具と部品
Slide the cover release button towards the bottom of the phone
Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
Once you have taken off the back cover of the phone, the charger tab can be lifted out of position on the back cover.
