メインコンテンツにスキップ
Motorola i450 Boost Mobile Headphone Port Replacement
必要な工具と部品
  1. Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: 手順 1、 3の画像 1 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: 手順 1、 3の画像 2 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: 手順 1、 3の画像 3
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Headphone Port Replacement, Battery: 手順 2、 3の画像 1 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: 手順 2、 3の画像 2 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: 手順 2、 3の画像 3
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: 手順 3、 2の画像 1 Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: 手順 3、 2の画像 2
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Headphone Port Replacement: 手順 4、 3の画像 1 Motorola i450 Boost Mobile Headphone Port Replacement: 手順 4、 3の画像 2 Motorola i450 Boost Mobile Headphone Port Replacement: 手順 4、 3の画像 3
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Headphone Port Replacement, Circuit Board: 手順 5、 1の画像 1
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Headphone Port Replacement: 手順 6、 1の画像 1
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Headphone Port Replacement: 手順 7、 3の画像 1 Motorola i450 Boost Mobile Headphone Port Replacement: 手順 7、 3の画像 2 Motorola i450 Boost Mobile Headphone Port Replacement: 手順 7、 3の画像 3
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  8. Motorola i450 Boost Mobile Headphone Port Replacement, Headphone Port: 手順 8、 1の画像 1
    • Locate the headphone port at the bottom right corner of the circuit board.
    • The headphone port cannot be removed from the phone. If cleaning the port does not fix the problem, the entire phone must be replaced.
終わりに
作成者
5人の作成者と共同で作成されました。
Garrison Stevens
メンバー登録日: 10/22/12
1 ポイント
6のガイドは作成済み
チーム
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012人のメンバー
CLEM-BENSON-F12S15G2
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 11
今までの合計 423
