はじめに
The circuit board controls whether any other function of the phone works at all. The circuit board cannot be replaced without replacing the entire unit, but removing it provides access to other replaceable parts.
  1. Place the phone on a flat surface with the front facing down. Insert your finger under the gray plastic cover at the bottom end of the phone. Lift the cover off the phone.
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Place your thumb in the notch in the lower left corner of the battery compartment. Lift the battery up and away from the phone. Remove the battery.
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Locate the metal slider that holds the SIM card in place. Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    今まで、何かを修理したことがありますか?ジーニアスです。
    あなたのリペアストーリーを#ImAGenius でシェアしてください。
    私たちは皆んな、ジーニアスです。
  5. Lift the metal flap to gain access to the bottom of the SIM card. Remove the SIM card by sliding it out parallel to the bottom of the flap. Remove the SIM card by sliding it out parallel to the bottom of the flap.
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  6. Extend the antenna.
    • Extend the antenna.
  7. Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  8. Gently lift off the back half of the phone and set to the side. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits. Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
まとめ
Amber King
メンバー登録日: 2012年10月22日
8 ポイント
2のガイドは作成済み
チーム
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012人のメンバー
CLEM-BENSON-F12S15G2
4 メンバー
16のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 383
