メインコンテンツにスキップ
Motorola i1000plus Keypad Circuit Board Replacement
必要な工具と部品
  1. Motorola i1000plus Keypad Circuit Board Replacement, Battery: 手順 1、 3の画像 1 Motorola i1000plus Keypad Circuit Board Replacement, Battery: 手順 1、 3の画像 2 Motorola i1000plus Keypad Circuit Board Replacement, Battery: 手順 1、 3の画像 3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Keypad Circuit Board Replacement, Antenna: 手順 2、 3の画像 1 Motorola i1000plus Keypad Circuit Board Replacement, Antenna: 手順 2、 3の画像 2 Motorola i1000plus Keypad Circuit Board Replacement, Antenna: 手順 2、 3の画像 3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Keypad Circuit Board Replacement, Back Cover: 手順 3、 3の画像 1 Motorola i1000plus Keypad Circuit Board Replacement, Back Cover: 手順 3、 3の画像 2 Motorola i1000plus Keypad Circuit Board Replacement, Back Cover: 手順 3、 3の画像 3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Keypad Circuit Board Replacement: 手順 4、 1の画像 1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Keypad Circuit Board Replacement: 手順 5、 1の画像 1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Keypad Circuit Board Replacement: 手順 6、 3の画像 1 Motorola i1000plus Keypad Circuit Board Replacement: 手順 6、 3の画像 2 Motorola i1000plus Keypad Circuit Board Replacement: 手順 6、 3の画像 3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
  7. Motorola i1000plus Keypad Circuit Board Replacement, Motherboard: 手順 7、 1の画像 1
    • Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
  8. Motorola i1000plus Keypad Circuit Board Replacement: 手順 8、 3の画像 1 Motorola i1000plus Keypad Circuit Board Replacement: 手順 8、 3の画像 2 Motorola i1000plus Keypad Circuit Board Replacement: 手順 8、 3の画像 3
    • Using a pair of tweezers, firmly grasp the connector at the top of the phone and pull the connector straight away from the phone.
    • Do not pull the connector off by the wire. This could damage or destroy the wire or connector.
  9. Motorola i1000plus Keypad Circuit Board Replacement: 手順 9、 2の画像 1 Motorola i1000plus Keypad Circuit Board Replacement: 手順 9、 2の画像 2
    • Unclip the ribbon cable, located underneath the motherboard, by using the spudger to push up on the dark brown part of the connector located on the circuit board.
    • Do not pull the motherboard too far away from the phone with the ribbon cable still connected. this will damage the cable or the motherboard.
  10. Motorola i1000plus Keypad Circuit Board Replacement: 手順 10、 2の画像 1 Motorola i1000plus Keypad Circuit Board Replacement: 手順 10、 2の画像 2
    • Remove the motherboard by firmly grasping the edges of the circuit board with one hand and the phone with the other and pulling up on the motherboard slightly and then pulling it straight down toward the bottom of the phone.
    • Be sure to pull straight down to disconnect the ribbon cable properly. Pulling in another direction may cause damage to the cable or the motherboard.
  11. Motorola i1000plus Keypad Circuit Board Replacement, Keypad Circuit Board: 手順 11、 3の画像 1 Motorola i1000plus Keypad Circuit Board Replacement, Keypad Circuit Board: 手順 11、 3の画像 2 Motorola i1000plus Keypad Circuit Board Replacement, Keypad Circuit Board: 手順 11、 3の画像 3
    • Flip the motherboard over 180 degrees.
    • Place a spudger in between the gold plate and the bottom of the circuit board.
    • Carefully use the spudger as a prying tool to lift the circuit board from the motherboard.
    • Be very careful not to insert the spudger too far or to apply too much pressure. It can easily damage the circuit board.
終わりに
作成者
3人の作成者と共同で作成されました。
Austin Lake
メンバー登録日: 10/18/13
501 ポイント
5のガイドは作成済み
チーム
Clemson, Team 13-3, Benson Fall 2013 Clemson, Team 13-3, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S13G3
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 224
