メインコンテンツにスキップ
Motorola g stylus battery Replacement
必要な工具と部品
  1. Motorola g stylus battery Replacement, remove  the sims card and tray: 手順 1、 2の画像 1 Motorola g stylus battery Replacement, remove  the sims card and tray: 手順 1、 2の画像 2
    • Use your sim card eject tool to remove the sim card and tray.
  2. Motorola g stylus battery Replacement, remove stylus: 手順 2、 1の画像 1
    • Remove your stylus pen from the phone.
  3. Motorola g stylus battery Replacement, removing the back of your phone: 手順 3、 3の画像 1 Motorola g stylus battery Replacement, removing the back of your phone: 手順 3、 3の画像 2 Motorola g stylus battery Replacement, removing the back of your phone: 手順 3、 3の画像 3
    • Using your heat gun or a hairdryer heat the back of the phone to loosen up the adhesive.
    • Now using your opening devices go along the edge of the phone slow and easy prying along the edges till they're loose.
    • As you're lifting up the back of your phone be sure you watch out for the fingerprint scanner, just keep it pushed down while you're lifting up the back of the phone .
  4. Motorola g stylus battery Replacement, top and botttom inside covers: 手順 4、 2の画像 1 Motorola g stylus battery Replacement, top and botttom inside covers: 手順 4、 2の画像 2
    • Here you will have 15 t4 screws on top and bottom to take out but be careful with the top cover because the finger sensor runs under it. You don't want to rip that
  5. Motorola g stylus battery Replacement, Removing the battery: 手順 5、 1の画像 1
    • Here we need to be careful that we don't damage the battery, so unhook the battery and its flex cable. Then carefully get one corner of the battery lifted up to where you can get a good grip to pull on it. You will have to pull it slower so you don't damage the battery once that is done you made it.
    • New line.
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Trent Weaver
メンバー登録日: 09/16/20
232 ポイント
1ガイドが承認済み
コメント 1 件
Yessir, you the man bro
0% 100% - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 86
今までの合計 7,745
