メインコンテンツにスキップ
Motorola Xoom Wifi Display Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Motorola Xoom Wifi Display Replacement, Back Cover Disassembly: 手順 1、 2の画像 1 Motorola Xoom Wifi Display Replacement, Back Cover Disassembly: 手順 1、 2の画像 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Display Replacement: 手順 2、 2の画像 1 Motorola Xoom Wifi Display Replacement: 手順 2、 2の画像 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Display Replacement: 手順 3、 3の画像 1 Motorola Xoom Wifi Display Replacement: 手順 3、 3の画像 2 Motorola Xoom Wifi Display Replacement: 手順 3、 3の画像 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Display Replacement, Battery: 手順 4、 2の画像 1 Motorola Xoom Wifi Display Replacement, Battery: 手順 4、 2の画像 2
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Display Replacement: 手順 5、 2の画像 1 Motorola Xoom Wifi Display Replacement: 手順 5、 2の画像 2
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
  6. Motorola Xoom Wifi Display Replacement, Speakers: 手順 6、 2の画像 1 Motorola Xoom Wifi Display Replacement, Speakers: 手順 6、 2の画像 2
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
  7. Motorola Xoom Wifi Display Replacement, Motherboard: 手順 7、 3の画像 1 Motorola Xoom Wifi Display Replacement, Motherboard: 手順 7、 3の画像 2 Motorola Xoom Wifi Display Replacement, Motherboard: 手順 7、 3の画像 3
    • Take a plastic opening tool and carefully pry off the touch screen controller connection.
    • Be careful with the black cover under the connection.
  8. Motorola Xoom Wifi Display Replacement: 手順 8、 3の画像 1 Motorola Xoom Wifi Display Replacement: 手順 8、 3の画像 2 Motorola Xoom Wifi Display Replacement: 手順 8、 3の画像 3
    • There are two relay wires that must be disconnected.
    • Pull both relay wires out of their connection ports.
    • Make sure to flip up the small black tab before you pull out the wire.
  9. Motorola Xoom Wifi Display Replacement: 手順 9、 2の画像 1 Motorola Xoom Wifi Display Replacement: 手順 9、 2の画像 2
    • Using a plastic opener, lift the metal bar clasping the wire harness to the motherboard.
  10. Motorola Xoom Wifi Display Replacement: 手順 10、 3の画像 1 Motorola Xoom Wifi Display Replacement: 手順 10、 3の画像 2 Motorola Xoom Wifi Display Replacement: 手順 10、 3の画像 3
    • There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
    • Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
    • Motherboard should lift out easily and completely.
  11. Motorola Xoom Wifi Display Replacement, Display: 手順 11、 2の画像 1 Motorola Xoom Wifi Display Replacement, Display: 手順 11、 2の画像 2
    • Use a T-6 screw driver to take out 17-4mm screws. They are located around the perimeter of the tablet.
    • Take the display out of the screen and the back panel.
  12. Motorola Xoom Wifi Display Replacement: 手順 12、 3の画像 1 Motorola Xoom Wifi Display Replacement: 手順 12、 3の画像 2 Motorola Xoom Wifi Display Replacement: 手順 12、 3の画像 3
    • Flip the display so it is facing up. There are screws around the outer edge of the display.
    • A T-5 screwdriver will take the 12-4.1mm screws out.
    • Use a plastic opening tool to carefully split the display case open. The display should come free.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
William Prins
メンバー登録日: 04/14/14
604 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S3G39
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 314
