メインコンテンツにスキップ
Motorola Xoom Wifi Battery Replacement
必要な工具と部品
  1. Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: 手順 1、 2の画像 1 Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: 手順 1、 2の画像 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Battery Replacement: 手順 2、 2の画像 1 Motorola Xoom Wifi Battery Replacement: 手順 2、 2の画像 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Battery Replacement: 手順 3、 3の画像 1 Motorola Xoom Wifi Battery Replacement: 手順 3、 3の画像 2 Motorola Xoom Wifi Battery Replacement: 手順 3、 3の画像 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Battery Replacement, Battery: 手順 4、 2の画像 1 Motorola Xoom Wifi Battery Replacement, Battery: 手順 4、 2の画像 2
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Battery Replacement: 手順 5、 2の画像 1 Motorola Xoom Wifi Battery Replacement: 手順 5、 2の画像 2
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
終わりに
6 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Andrew Mercier
メンバー登録日: 04/14/14
532 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S3G39
4 メンバー
16のガイドは作成済み
コメント 1 件
does anyone know what the function of the black and red wires are? my connector came off the motherboard.
Duli - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 4,603
