メインコンテンツにスキップ
Motorola Xoom Wifi Back-Facing Camera Replacement
必要な工具と部品
  1. Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: 手順 1、 2の画像 1 Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: 手順 1、 2の画像 2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Back-Facing Camera Replacement: 手順 2、 2の画像 1 Motorola Xoom Wifi Back-Facing Camera Replacement: 手順 2、 2の画像 2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Back-Facing Camera Replacement: 手順 3、 3の画像 1 Motorola Xoom Wifi Back-Facing Camera Replacement: 手順 3、 3の画像 2 Motorola Xoom Wifi Back-Facing Camera Replacement: 手順 3、 3の画像 3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: 手順 4、 2の画像 1 Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: 手順 4、 2の画像 2
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  5. Motorola Xoom Wifi Back-Facing Camera Replacement: 手順 5、 2の画像 1 Motorola Xoom Wifi Back-Facing Camera Replacement: 手順 5、 2の画像 2
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Andrew Mercier
メンバー登録日: 04/14/14
532 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S3G39
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 392
