はじめに
The speakers in your device function as the medium for noise to travel from the device to your ears. When the volume is set too loud over an extended period of time, your speakers may produce distorted sounds and noises. In addition, any debris within the speakers may disrupt the sounds coming out of the speakers.
If the speakers of your Motorola Xoom 2 are not working, damaged, punctured, or otherwise non-functional, this guide can help you replace them.
必要な工具と部品
Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
ある他の人がこのガイドを完成しました。
