メインコンテンツにスキップ
Motorola W385 speaker replacement
必要な工具と部品
  1. Motorola W385 speaker replacement, Battery: 手順 1、 1の画像 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 speaker replacement: 手順 2、 1の画像 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 speaker replacement, Front Casing: 手順 3、 1の画像 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 speaker replacement: 手順 4、 1の画像 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 speaker replacement: 手順 5、 2の画像 1 Motorola W385 speaker replacement: 手順 5、 2の画像 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 speaker replacement: 手順 6、 1の画像 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 speaker replacement, Top Logic Board: 手順 7、 1の画像 1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 speaker replacement: 手順 8、 3の画像 1 Motorola W385 speaker replacement: 手順 8、 3の画像 2 Motorola W385 speaker replacement: 手順 8、 3の画像 3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 speaker replacement: 手順 9、 3の画像 1 Motorola W385 speaker replacement: 手順 9、 3の画像 2 Motorola W385 speaker replacement: 手順 9、 3の画像 3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
  10. Motorola W385 speaker replacement, Main Speaker: 手順 10、 1の画像 1
    • Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
  11. Motorola W385 speaker replacement: 手順 11、 2の画像 1 Motorola W385 speaker replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    • Place the spudger between the speaker and the clip shown.
    • Separate the clip from the speaker while lifting on the speaker.
    • The speaker should separate. Use the tweezers to grab the speaker.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Koedy Brant
メンバー登録日: 01/26/10
41 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G50
3 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 3,182
