メインコンテンツにスキップ
Motorola W385 Top Logic Board Replacement
必要な工具と部品
  1. Motorola W385 Top Logic Board Replacement, Battery: 手順 1、 1の画像 1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Top Logic Board Replacement: 手順 2、 1の画像 1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Top Logic Board Replacement, Front Casing: 手順 3、 1の画像 1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Top Logic Board Replacement: 手順 4、 1の画像 1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Top Logic Board Replacement: 手順 5、 2の画像 1 Motorola W385 Top Logic Board Replacement: 手順 5、 2の画像 2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Top Logic Board Replacement: 手順 6、 1の画像 1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 Top Logic Board Replacement, Top Logic Board: 手順 7、 1の画像 1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 Top Logic Board Replacement: 手順 8、 3の画像 1 Motorola W385 Top Logic Board Replacement: 手順 8、 3の画像 2 Motorola W385 Top Logic Board Replacement: 手順 8、 3の画像 3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 Top Logic Board Replacement: 手順 9、 3の画像 1 Motorola W385 Top Logic Board Replacement: 手順 9、 3の画像 2 Motorola W385 Top Logic Board Replacement: 手順 9、 3の画像 3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
終わりに
作成者
4人の作成者と共同で作成されました。
Javier Mendez
メンバー登録日: 01/21/10
13 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G50
3 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 9
今までの合計 2,561
