この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This will show you how to replace your camera.
必要な工具と部品
Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
Close the phone before proceeding.
Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
Continue to move around the phone counter clockwise until the casing is separated from the body.
After completing Steps 3-6 in the casing repair guide, your phone should look like this.
ある他の人がこのガイドを完成しました。
