メインコンテンツにスキップ
Motorola W315 Keypad Replacement
必要な工具と部品
  1. Motorola W315 Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Keypad Replacement: 手順 3、 1の画像 1
    • Insert the new battery.
  3. Motorola W315 Keypad Replacement, Rear Case: 手順 4、 1の画像 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Keypad Replacement: 手順 5、 3の画像 1 Motorola W315 Keypad Replacement: 手順 5、 3の画像 2 Motorola W315 Keypad Replacement: 手順 5、 3の画像 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Keypad Replacement, Circuit Board: 手順 6、 3の画像 1 Motorola W315 Keypad Replacement, Circuit Board: 手順 6、 3の画像 2 Motorola W315 Keypad Replacement, Circuit Board: 手順 6、 3の画像 3
    • Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
  6. Motorola W315 Keypad Replacement: 手順 7、 3の画像 1 Motorola W315 Keypad Replacement: 手順 7、 3の画像 2 Motorola W315 Keypad Replacement: 手順 7、 3の画像 3
    • Use the plastic opening tool to remove the chip connected by magnetic strip to the screen.
    • Remove circuit board.
  7. Motorola W315 Keypad Replacement, Keypad: 手順 8、 3の画像 1 Motorola W315 Keypad Replacement, Keypad: 手順 8、 3の画像 2 Motorola W315 Keypad Replacement, Keypad: 手順 8、 3の画像 3
    • Apply pressure to the side buttons to remove them from the frame.
    • Turn the device over and push the keypad to loosen it from the frame.
    • Turn the device over again and gently pull the keypad away from the frame.
    • Warning: Keypad may not respond due to unclean button contacts, make sure the button contacts remain clean throughout the disassembly and reassembly of the phone.
終わりに
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
作成者
4人の作成者と共同で作成されました。
Justin Scott
メンバー登録日: 03/26/14
501 ポイント
5のガイドは作成済み
チーム
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014人のメンバー
CLEM-BENSON-S14S6G3
3 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 180
