メインコンテンツにスキップ
Motorola V710 Speaker Replacement
必要な工具と部品
  1. Motorola V710 Speaker Replacement, Battery: 手順 1、 3の画像 1 Motorola V710 Speaker Replacement, Battery: 手順 1、 3の画像 2 Motorola V710 Speaker Replacement, Battery: 手順 1、 3の画像 3
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Speaker Replacement: 手順 2、 3の画像 1 Motorola V710 Speaker Replacement: 手順 2、 3の画像 2 Motorola V710 Speaker Replacement: 手順 2、 3の画像 3
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Speaker Replacement, Logic Board: 手順 3、 2の画像 1 Motorola V710 Speaker Replacement, Logic Board: 手順 3、 2の画像 2
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Speaker Replacement: 手順 4、 2の画像 1 Motorola V710 Speaker Replacement: 手順 4、 2の画像 2
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Speaker Replacement: 手順 5、 3の画像 1 Motorola V710 Speaker Replacement: 手順 5、 3の画像 2 Motorola V710 Speaker Replacement: 手順 5、 3の画像 3
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Speaker Replacement: 手順 6、 2の画像 1 Motorola V710 Speaker Replacement: 手順 6、 2の画像 2
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Speaker Replacement: 手順 7、 2の画像 1 Motorola V710 Speaker Replacement: 手順 7、 2の画像 2
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Speaker Replacement: 手順 8、 3の画像 1 Motorola V710 Speaker Replacement: 手順 8、 3の画像 2 Motorola V710 Speaker Replacement: 手順 8、 3の画像 3
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Speaker Replacement: 手順 9、 1の画像 1
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Speaker Replacement: 手順 10、 2の画像 1 Motorola V710 Speaker Replacement: 手順 10、 2の画像 2
    • Remove the logic board.
  11. Motorola V710 Speaker Replacement, Replacing Speaker: 手順 11、 2の画像 1 Motorola V710 Speaker Replacement, Replacing Speaker: 手順 11、 2の画像 2
    • Use the spudger take the speaker out.
終わりに
作成者
4人の作成者と共同で作成されました。
Karl Sanders
メンバー登録日: 01/26/10
8 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G49
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,036
