メインコンテンツにスキップ
Motorola V710 Camera Replacement
必要な工具と部品
  1. Motorola V710 Camera Replacement, Screen: 手順 1、 3の画像 1 Motorola V710 Camera Replacement, Screen: 手順 1、 3の画像 2 Motorola V710 Camera Replacement, Screen: 手順 1、 3の画像 3
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
  2. Motorola V710 Camera Replacement: 手順 2、 2の画像 1 Motorola V710 Camera Replacement: 手順 2、 2の画像 2
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
  3. Motorola V710 Camera Replacement: 手順 3、 2の画像 1 Motorola V710 Camera Replacement: 手順 3、 2の画像 2
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
  4. Motorola V710 Camera Replacement: 手順 4、 2の画像 1 Motorola V710 Camera Replacement: 手順 4、 2の画像 2
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
  5. Motorola V710 Camera Replacement: 手順 5、 2の画像 1 Motorola V710 Camera Replacement: 手順 5、 2の画像 2
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
  6. Motorola V710 Camera Replacement: 手順 6、 2の画像 1 Motorola V710 Camera Replacement: 手順 6、 2の画像 2
    • Use the spudger to remove the screen.
  7. Motorola V710 Camera Replacement, Camera: 手順 7、 3の画像 1 Motorola V710 Camera Replacement, Camera: 手順 7、 3の画像 2 Motorola V710 Camera Replacement, Camera: 手順 7、 3の画像 3
    • Use the spudger to remove the camera module.
    • Note: The camera has an adhesive holding it in place, so a slight force is necessary to remove it.
終わりに
作成者
4人の作成者と共同で作成されました。
Karl Sanders
メンバー登録日: 01/26/10
8 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G49
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,560
