メインコンテンツにスキップ
Motorola V60s Logic Board Replacement
必要な工具と部品
  1. Motorola V60s Logic Board Replacement, Battery: 手順 1、 3の画像 1 Motorola V60s Logic Board Replacement, Battery: 手順 1、 3の画像 2 Motorola V60s Logic Board Replacement, Battery: 手順 1、 3の画像 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Logic Board Replacement: 手順 2、 2の画像 1 Motorola V60s Logic Board Replacement: 手順 2、 2の画像 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Logic Board Replacement, Logic Board: 手順 3、 2の画像 1 Motorola V60s Logic Board Replacement, Logic Board: 手順 3、 2の画像 2
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Logic Board Replacement: 手順 4、 3の画像 1 Motorola V60s Logic Board Replacement: 手順 4、 3の画像 2 Motorola V60s Logic Board Replacement: 手順 4、 3の画像 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Logic Board Replacement: 手順 5、 3の画像 1 Motorola V60s Logic Board Replacement: 手順 5、 3の画像 2 Motorola V60s Logic Board Replacement: 手順 5、 3の画像 3
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Logic Board Replacement: 手順 6、 3の画像 1 Motorola V60s Logic Board Replacement: 手順 6、 3の画像 2 Motorola V60s Logic Board Replacement: 手順 6、 3の画像 3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Logic Board Replacement: 手順 7、 2の画像 1 Motorola V60s Logic Board Replacement: 手順 7、 2の画像 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Eric Freeman
メンバー登録日: 01/26/10
10 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S8G48
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,865
