はじめに
Step-by-step guide to replacing the keypad sensor.
パーツ
パーツは必要ありません。
  1. Flip phone to see back cover. Using either finger or spugder tool press button located  near the top of phone by the antenna.
    • Flip phone to see back cover.
    • Using either finger or spugder tool press button located near the top of phone by the antenna.
  2. Pry up back plate from phone to reveal battery. Push button near bottom of battery using either your finger of the spudger.  This will release the battery.
    • Pry up back plate from phone to reveal battery.
    • Push button near bottom of battery using either your finger of the spudger. This will release the battery.
  3. Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
    • Using a T6 Torx Screwdriver remove the four torxs on the back of the phone.
  4. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  5. Simultaneously press indicated buttons on both sides of phone. Simultaneously press indicated buttons on both sides of phone.
    • Simultaneously press indicated buttons on both sides of phone.
  6. Separate back plate from the rest of phone.
    • Separate back plate from the rest of phone.
    • Make sure to not pull, there is a wire (circled on image) connecting the two plates.
  7. Gently lift logic board from back plate.
    • Gently lift logic board from back plate.
  8. Place logic board on front cover. Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
  9. Once logic board is removed lift the green keypad sensor for the front plate. Once logic board is removed lift the green keypad sensor for the front plate.
    • Once logic board is removed lift the green keypad sensor for the front plate.
まとめ
Elizabeth OBrien
メンバー登録日: 2010年04月26日
31 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S30G40
4 メンバー
14のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,842
