メインコンテンツにスキップ
Motorola V60c Keypad and Keypad Logic Board Replacement
必要な工具と部品
  1. Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: 手順 1、 2の画像 1 Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: 手順 1、 2の画像 2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 2、 2の画像 1 Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 2、 2の画像 2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Keypad and Keypad Logic Board Replacement, Keypad and Keypad Logic Board: 手順 3、 1の画像 1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 4、 2の画像 1 Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 4、 2の画像 2
    • Use plastic opening tool to pry up back cover from two side clips.
    • NOTE: Sticker might be attached to rest of phone.
  5. Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 5、 1の画像 1
    • Remove the back cover.
  6. Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 6、 2の画像 1 Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 7、 2の画像 1 Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 7、 2の画像 2
    • Remove the keypad logic board.
    • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  8. Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 8、 3の画像 1 Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 8、 3の画像 2 Motorola V60c Keypad and Keypad Logic Board Replacement: 手順 8、 3の画像 3
    • Remove the keypad.
終わりに
作成者
6人の作成者と共同で作成されました。
Ryan Kuroiwa
メンバー登録日: 04/10/10
1 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-86, Amido Spring 2010 Cal Poly, Team 25-86, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G86
5 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 2,211
