メインコンテンツにスキップ
Motorola V557 Internal Speaker Replacement
必要な工具と部品
  1. Motorola V557 Internal Speaker Replacement, Battery: 手順 1、 3の画像 1 Motorola V557 Internal Speaker Replacement, Battery: 手順 1、 3の画像 2 Motorola V557 Internal Speaker Replacement, Battery: 手順 1、 3の画像 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Internal Speaker Replacement: 手順 2、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 2、 2の画像 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Internal Speaker Replacement, Faceplate: 手順 3、 3の画像 1 Motorola V557 Internal Speaker Replacement, Faceplate: 手順 3、 3の画像 2 Motorola V557 Internal Speaker Replacement, Faceplate: 手順 3、 3の画像 3
    • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
  4. Motorola V557 Internal Speaker Replacement: 手順 4、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 4、 2の画像 2
    • Remove the four 3.8 mm T-6 Torx screws.
  5. Motorola V557 Internal Speaker Replacement: 手順 5、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 5、 2の画像 2
    • Separate the cover from the edges using a plastic opening tool.
  6. Motorola V557 Internal Speaker Replacement: 手順 6、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 6、 2の画像 2
    • With the edges separated, close the phone and lift off the faceplate with your fingers.
  7. Motorola V557 Internal Speaker Replacement, Camera: 手順 7、 1の画像 1
    • Gently peel off the plastic film from the metal plate above the camera lens as shown.
  8. Motorola V557 Internal Speaker Replacement: 手順 8、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 8、 2の画像 2
    • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
    • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
  9. Motorola V557 Internal Speaker Replacement: 手順 9、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 9、 2の画像 2
    • Lift and peel back the tape attaching metal casing to body of the phone.
    • Gently lift the metal cover and remove to expose the circuit board.
  10. Motorola V557 Internal Speaker Replacement: 手順 10、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 10、 2の画像 2
    • Using a plastic opening tool, pry or lift open the pink door shown.
    • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
    • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
  11. Motorola V557 Internal Speaker Replacement: 手順 11、 3の画像 1 Motorola V557 Internal Speaker Replacement: 手順 11、 3の画像 2 Motorola V557 Internal Speaker Replacement: 手順 11、 3の画像 3
    • Use a plastic opening tool to dislodge and remove the rubber camera cover.
  12. Motorola V557 Internal Speaker Replacement: 手順 12、 2の画像 1 Motorola V557 Internal Speaker Replacement: 手順 12、 2の画像 2
    • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
  13. Motorola V557 Internal Speaker Replacement, Screen: 手順 13、 3の画像 1 Motorola V557 Internal Speaker Replacement, Screen: 手順 13、 3の画像 2 Motorola V557 Internal Speaker Replacement, Screen: 手順 13、 3の画像 3
    • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
    • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
  14. Motorola V557 Internal Speaker Replacement, Internal Speaker: 手順 14、 2の画像 1 Motorola V557 Internal Speaker Replacement, Internal Speaker: 手順 14、 2の画像 2
    • Pry the speaker out of the case by wedging a pin under the wire mesh.
    • The speaker is glued to the case. It will take some effort to remove, but don't worry, it is not fragile.
終わりに
作成者
5人の作成者と共同で作成されました。
Matthew Sanders
メンバー登録日: 10/04/10
43 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S7G50
4 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,561
