メインコンテンツにスキップ
Motorola V557 Headphone Jack Replacement
必要な工具と部品
  1. Motorola V557 Headphone Jack Replacement, Battery: 手順 1、 3の画像 1 Motorola V557 Headphone Jack Replacement, Battery: 手順 1、 3の画像 2 Motorola V557 Headphone Jack Replacement, Battery: 手順 1、 3の画像 3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Headphone Jack Replacement: 手順 2、 2の画像 1 Motorola V557 Headphone Jack Replacement: 手順 2、 2の画像 2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Headphone Jack Replacement, SIM Card: 手順 3、 3の画像 1 Motorola V557 Headphone Jack Replacement, SIM Card: 手順 3、 3の画像 2 Motorola V557 Headphone Jack Replacement, SIM Card: 手順 3、 3の画像 3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Headphone Jack Replacement, Antenna: 手順 4、 2の画像 1 Motorola V557 Headphone Jack Replacement, Antenna: 手順 4、 2の画像 2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Headphone Jack Replacement, Rear Casing: 手順 5、 3の画像 1 Motorola V557 Headphone Jack Replacement, Rear Casing: 手順 5、 3の画像 2 Motorola V557 Headphone Jack Replacement, Rear Casing: 手順 5、 3の画像 3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Headphone Jack Replacement: 手順 6、 3の画像 1 Motorola V557 Headphone Jack Replacement: 手順 6、 3の画像 2 Motorola V557 Headphone Jack Replacement: 手順 6、 3の画像 3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Headphone Jack Replacement: 手順 7、 3の画像 1 Motorola V557 Headphone Jack Replacement: 手順 7、 3の画像 2 Motorola V557 Headphone Jack Replacement: 手順 7、 3の画像 3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
  8. Motorola V557 Headphone Jack Replacement, Headphone Jack: 手順 8、 3の画像 1 Motorola V557 Headphone Jack Replacement, Headphone Jack: 手順 8、 3の画像 2 Motorola V557 Headphone Jack Replacement, Headphone Jack: 手順 8、 3の画像 3
    • Lastly, using a push pin, lift out and to the left to release the headphone jack assembly.
    • Insert the new headphone jack assembly and repeat these steps in reverse order.
終わりに
作成者
8人の作成者と共同で作成されました。
Alex Georges
メンバー登録日: 10/02/10
40 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010人のメンバー
CPSU-AMIDO-F10S7G50
4 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,653
