メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This is a guide showing how to replace and repair the keypad of the phone.
パーツ
パーツは指定されていません。
  1. Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery
    • Push down on the chrome button at the bottom of the back of the phone. Slide the outer casing down to reveal the battery
  2. Apply pressure to the bottom corners of the battery, and then push upwards to lever the battery out.
    • Apply pressure to the bottom corners of the battery, and then push upwards to lever the battery out.
  3. Remove the rubber screw covers using a plastic spudger. Use a T-6 screw bit to remove the screws. Use a T-6 screw bit to remove the screws.
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T-6 screw bit to remove the screws.
  4. Unscrew the antenna.
    • Unscrew the antenna.
  5. Use a plastic opening tool to undo the latches at the indicated spots. Dental tools may be used in place of a plastic opening tool, as they are difficult to use. Warning: exercise caution as the plastic can break.
    • Use a plastic opening tool to undo the latches at the indicated spots.
    • Dental tools may be used in place of a plastic opening tool, as they are difficult to use.
    • Warning: exercise caution as the plastic can break.
  6. Remove the circuit board connection (copper flap) by first loosening it with a plastic opening tool. Lift the connection up with your finger.
    • Remove the circuit board connection (copper flap) by first loosening it with a plastic opening tool.
    • Lift the connection up with your finger.
  7. Use your finger to remove the pressure pad from the buttons on the side of the casing. Remove the plastic flap from around the buttons by lifting it up and pulling it out. Gently lift the logic board up.
    • Use your finger to remove the pressure pad from the buttons on the side of the casing.
    • Remove the plastic flap from around the buttons by lifting it up and pulling it out.
    • Gently lift the logic board up.
  8. Push both side keys in so they are not sticking out of the phone. Remove the keypad. Remove the keypad.
    • Push both side keys in so they are not sticking out of the phone.
    • Remove the keypad.
終わりに
2 の人々がこのガイドを完成させました。
gregatron
メンバー登録日: 2009年10月29日
105 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 6-6, Maness Fall 2009 Cal Poly, Team 6-6, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S6G6
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,984
