はじめに
This guide is for replacing a key on the keypad. Super glue is required.
必要な工具と部品
Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
Remove the rubber screw covers using a plastic spudger.
Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
ある他の人がこのガイドを完成しました。
