メインコンテンツにスキップ
Motorola V325 Logic Board Replacement
必要な工具と部品
  1. Motorola V325 Logic Board Replacement, Battery: 手順 1、 1の画像 1
    • Flip the phone over so that the back is visible.
    • Push down on the silver button using your fingernail or thumbnail. Push down all the way until the button stops.
  2. Motorola V325 Logic Board Replacement: 手順 2、 3の画像 1 Motorola V325 Logic Board Replacement: 手順 2、 3の画像 2 Motorola V325 Logic Board Replacement: 手順 2、 3の画像 3
    • While holding down the silver button, simultaneously pull downward on the rear cover, then lift it off to reveal the battery.
    • This will only take a moment to do.
  3. Motorola V325 Logic Board Replacement: 手順 3、 3の画像 1 Motorola V325 Logic Board Replacement: 手順 3、 3の画像 2 Motorola V325 Logic Board Replacement: 手順 3、 3の画像 3
    • Using your thumbnail and fingernail, grip the battery where indicated as "pull here" and lift the battery upward, starting at that side.
    • Remove the battery completely by lifting it straight out of the phone.
  4. Motorola V325 Logic Board Replacement: 手順 4、 1の画像 1
    • When replacing the battery, ensure that the side that has the "pull here" arrows goes toward the bottom of the phone. Place the side of the battery with the metallic contacts in toward the inside of the phone, making a full connection with the contacts within the phone (shown in the red rectangle).
  5. Motorola V325 Logic Board Replacement, Rear Panel: 手順 5、 3の画像 1 Motorola V325 Logic Board Replacement, Rear Panel: 手順 5、 3の画像 2 Motorola V325 Logic Board Replacement, Rear Panel: 手順 5、 3の画像 3
    • Using a small flat head screwdriver or your fingernail, remove the rubber covers near the top of the phone
  6. Motorola V325 Logic Board Replacement: 手順 6、 3の画像 1 Motorola V325 Logic Board Replacement: 手順 6、 3の画像 2 Motorola V325 Logic Board Replacement: 手順 6、 3の画像 3
    • There are four Torx screws located on the four corners of the rear panel
    • Remove all four screws using the T6 Torx Screwdriver.
  7. Motorola V325 Logic Board Replacement: 手順 7、 3の画像 1 Motorola V325 Logic Board Replacement: 手順 7、 3の画像 2 Motorola V325 Logic Board Replacement: 手順 7、 3の画像 3
    • Unscrew the antenna.
    • Remove the antenna protective tubing
  8. Motorola V325 Logic Board Replacement: 手順 8、 3の画像 1 Motorola V325 Logic Board Replacement: 手順 8、 3の画像 2 Motorola V325 Logic Board Replacement: 手順 8、 3の画像 3
    • There are four light gray tabs located around the phone (two on each side)
    • Using your finger nail or a flat head screwdriver, pull the gray tab away from the body while simultaneously lifting upward on the black rear panel.
    • Once all four tabs are removed, lift up the back panel to reveal the interior logic board.
  9. Motorola V325 Logic Board Replacement, Logic Board: 手順 9、 3の画像 1 Motorola V325 Logic Board Replacement, Logic Board: 手順 9、 3の画像 2 Motorola V325 Logic Board Replacement, Logic Board: 手順 9、 3の画像 3
    • Place finger at the indicated area.
    • Gently detach the cable as shown in the picture. This is easiest to do by grabbing the corner.
  10. Motorola V325 Logic Board Replacement: 手順 10、 2の画像 1 Motorola V325 Logic Board Replacement: 手順 10、 2の画像 2
    • After detaching the cable you can then completely take the logic board out.
    • Connect the new logic board by plugging the cable into the same port as the old logic board.
終わりに
作成者
5人の作成者と共同で作成されました。
Minh Tran
メンバー登録日: 01/15/10
2 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-15, Forte Winter 2010 Cal Poly, Team 4-15, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S4G15
5 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 17
今までの合計 2,690
