メインコンテンツにスキップ
Motorola V276 Speaker Replacement
必要な工具と部品
  1. Motorola V276 Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
  2. Motorola V276 Speaker Replacement: 手順 2、 1の画像 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
  3. Motorola V276 Speaker Replacement: 手順 3、 2の画像 1 Motorola V276 Speaker Replacement: 手順 3、 2の画像 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
  4. Motorola V276 Speaker Replacement, Speaker: 手順 4、 1の画像 1
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
  5. Motorola V276 Speaker Replacement: 手順 5、 1の画像 1
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
  6. Motorola V276 Speaker Replacement: 手順 6、 3の画像 1 Motorola V276 Speaker Replacement: 手順 6、 3の画像 2 Motorola V276 Speaker Replacement: 手順 6、 3の画像 3
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
  7. Motorola V276 Speaker Replacement: 手順 7、 2の画像 1 Motorola V276 Speaker Replacement: 手順 7、 2の画像 2
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
  8. Motorola V276 Speaker Replacement: 手順 8、 2の画像 1 Motorola V276 Speaker Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
  9. Motorola V276 Speaker Replacement: 手順 9、 1の画像 1
    • Using a spudger, remove the speaker
終わりに
作成者
3人の作成者と共同で作成されました。
Kyle Klitzner
メンバー登録日: 04/11/10
1 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S27G96
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 1,017
